Visitor darking2539
How to generate PWM triangular carrier by AXI Timer in SDK
The Vivado Ver. 2018.3 is already support the PWM Mode in AXI Timer but the function of instant PWM is Generate by use down count mode The first question is in the bottom picture the down count mode is PWM that generate with SAWTOOTH carrier right?
And if i want to generate The PWM by use Triangular carrier for the motor drive application How can i adapt C code in PWM example in ( C:\Xilinx\SDK\2018.3\data\embeddedsw\XilinxProcessorIPLib\drivers\tmrctr_v4_5 ) .
Thank for help
