I got the problem in dumping the code in v2pro
iam taking simple example like led blinking , iam coonected rs233 and jtag cable it reults error
 after generating the bit file like this how to configure the v2 pro my  sw 8  isall switches are  up  sw9 all switches are down and one more thing is after getting power on the system ACe led D11 blinking status error repotred how i avoid this problem
Downloading Bitstream onto the target board
impact -batch etc/download.cmd
Release 10.1.02 - iMPACT K.37 (nt)
Copyright (c) 1995-2008 Xilinx, Inc.  All rights reserved.
Preference Table
Name                 Setting
StartupClock         Auto_Correction
AutoSignature        False
KeepSVF              False
ConcurrentMode       False
UseHighz             False
ConfigOnFailure      Stop
UserLevel            Novice
MessageLevel         Detailed
svfUseTime           false
SpiByteSwap          Auto_Correction
AutoDetecting cable. Please wait.
Connecting to cable (Parallel Port - LPT1).
Checking cable driver.
 Driver windrvr6.sys version = 8.1.1.0. WinDriver v8.11 Jungo (c) 1997 - 2006 Build Date: Oct 16 2006 X86 32bit SYS
12:35:07, version = 811.
 LPT base address = 0378h.
 ECP base address = 0778h.
Cable connection failed.
Connecting to cable (Parallel Port - LPT2).
Connecting to cable (Parallel Port - LPT3).
Connecting to cable (Parallel Port - LPT4).
Connecting to cable (Usb Port - USB21).
 Driver file xusbdfwu.sys found.
 Driver version: src=1027, dest=1027.
 Cable PID = 0008.
 Max current requested during enumeration is 150 mA.
Type = 0x0605.
 Cable Type = 3, Revision = 0.
 Setting cable speed to 6 MHz.
Cable connection established.
Firmware version = 1027.
File version of c:/Xilinx/10.1/ISE/data/xusbdfwu.hex = 1028.
Firmware hex file version = 1028.
Downloading c:/Xilinx/10.1/ISE/data/xusbdfwu.hex.
Downloaded firmware version = 1028.
PLD file version = 0012h.
 PLD version = 0012h.
Identifying chain contents ....'1': : Manufacturer's ID =Xilinx xc2vp30, Version : 1
INFO:iMPACT:1777 -
   Reading c:/Xilinx/10.1/ISE/virtex2p/data/xc2vp30.bsd...
'2': : Manufacturer's ID =Xilinx xccace, Version : 0
INFO:iMPACT:501 - '1': Added Device xc2vp30 successfully.
'3': : Manufacturer's ID =Xilinx xcf32p, Version : 15
INFO:iMPACT:1777 -
   Reading c:/Xilinx/10.1/ISE/acecf/data/xccace.bsd...
INFO:iMPACT:501 - '1': Added Device xccace successfully.
INFO:iMPACT:1777 -
   Reading c:/Xilinx/10.1/ISE/xcfp/data/xcf32p.bsd...
INFO:iMPACT:501 - '1': Added Device xcf32p successfully.
done.
Elapsed time =      0 sec.
'2': Loading file 'implementation/download.bit' ...
done.
INFO:iMPACT:501 - '2': Added Device xc2vp30 successfully.
INFO:iMPACT:583 - '2': The idcode read from the device does not match the idcode
   in the bsdl File.
INFO:iMPACT:1578 - '2':  Device IDCODE :        00000000000000000000000000000000
INFO:iMPACT:1579 - '2': Expected IDCODE:    00000001001001111110000010010011
make: *** [download] Error 1
Done!
Observer ifen_gmbh
Re: I got the problem in dumping the code in v2pro
we have had a similar problem with the different IDCODEs
The problem was, that the JTAG connector wasn't soldered correctly. The device was identified, but it wasn't possible to program.
So, check the connector on the PCB.
Best regards, Nico
