Visitor drinu8
Once I remove GPIO Interrupt handler, UARTlite Interrupt works, else it does not.
Something weird is happening - with reference to the code below, when I comment the gpio handler (ihandler_gpo2), the interrupt of the uart (transmitting) is handled successfully, whilst when I uncomment the handler, the interrupt is not handled. In both modes, the data is transmitted via the FPGA. I tried commenting everything in the gpio handler, and leaving the function 'title' - similar to the prototype, but without a semicolon but to no avail. I am not sure what I am doing wrong.
Any help would be greatly appreciated as I have no idea why this is happening apart from that it's something that has to do with the gpio interrupts.
just FYI, I am using SDK, and the system debugger.
int main()
    init_peripherals(&gpio2, &uart0);
	xil_printf("1 - ");
	XUartLite_Recv(&uart0, recbuf, 2);
	xil_printf("2 - ");
	XUartLite_Send(&uart0, sendbuf, 2);
	xil_printf("3 - ");
	while ((TotalSentCount != 2)) {
	xil_printf("4 - ");
	xil_printf("uart done\n\r");
    while(1)
    return 0;
void init_peripherals(XGpio *Gpio2Ptr, XUartLite *UartLitePtr)
	// initialise GPIO
	status = XGpio_Initialize (&gpio0,gpio_id);
	status = status + XGpio_Initialize (&gpio1,gpio1_id);
	status = status + XGpio_Initialize (&gpio2,gpio2_id);
	initialise_check("GPIO", status);
	// data direction for gpio0 | 0 out, 1 input
	XGpio_SetDataDirection (&gpio2,2, (cb_data | cb_clk | cb_m_alrt | PLL_STAT | reset | hdr ) & (~(cb_s_alrt | DAC_dn | PLL_dn | LED | LEDs )));
	XGpio_SetDataDirection (&gpio2,1, 0);
	XGpio_DiscreteSet(&gpio2,2,cb_s_alrt);
	//UART initialisation
	status = XUartLite_Initialize (UartLitePtr, uart_id);
	status = status + XUartLite_SelfTest(UartLitePtr);
	initialise_check("UART", status);
	//interrupt initialisation
	status = XIntc_Initialize(&int_con, int_id);
	//connecting interrupt handlers
	status = status + XIntc_Connect(&int_con, int_uart_id,(XInterruptHandler)XUartLite_InterruptHandler, (void *)UartLitePtr);	//uart
	//status = status + XIntc_Connect(&int_con, int_cbus_id, (XInterruptHandler)ihandler_gpo2, (void *)Gpio2Ptr); 	// gpio
	//start interrupt
	status = status + XIntc_Start(&int_con, XIN_REAL_MODE);//XIN_SIMULATION_MODE XIN_REAL_MODE
	//XIntc_Enable(&int_con, int_cbus_id); // gpio
	XIntc_Enable(&int_con, int_uart_id); // uart
	initialise_check("Interrupts", status);
	//gpio interrupt enable
	XGpio_InterruptEnable(&gpio2, XGPIO_IR_CH2_MASK);//XGPIO_IR_CH2_MASK
	XGpio_InterruptGlobalEnable(&gpio2);
	XGpio_InterruptClear(&gpio2,0x02); // 0x02 - for channel 2
	//uart interrupt settings
	XUartLite_SetSendHandler(UartLitePtr, MySendHandler, UartLitePtr);
	XUartLite_SetRecvHandler(UartLitePtr, MyRecvHandler, UartLitePtr);
	XUartLite_EnableInterrupt(UartLitePtr);
	xil_printf("interrupt enabled");
	//register exception handler with interrupt controller table
	Xil_ExceptionInit();
	Xil_ExceptionRegisterHandler(XIL_EXCEPTION_ID_INT,(Xil_ExceptionHandler)XIntc_InterruptHandler,	&int_con);
	Xil_ExceptionEnable();
void MySendHandler(void *CallBackRef, unsigned int EventData)
	TotalSentCount = EventData;
	xil_printf("datasent\n\r");
	XUartLite_ResetFifos (&uart0 );
void MyRecvHandler(void *CallBackRef, unsigned int EventData)
	TotalReceivedCount = EventData;
void ihandler_gpo2 (void *InstancePtr)
	u32 dataread;
	static u32 dataread_before = 0;
	dataread = XGpio_DiscreteRead(&gpio2,2);
	//xil_printf("data read is - %x \n\r", dataread);
	//if (((dataread & (0x1<pll_stat)) == 0) && ((dataread_before & (0x1<<pll_stat)) > 0))
		// PLL Output is not locked!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
		// Do something :(
		//gpo0 = gpo0 & (~mb_clken);
		//XGpio_DiscreteWrite(&gpio1, 1, gpo0);
		//set a flag?
		//xil_printf("LTC6946 not locked");
	//else
		if ((dataread & 0xFF) != (dataread_before & 0xFF))
		//checking whether there has been any change in the bus
			if (((dataread & cb_m_alrt) == 0) && (rx != 1) && (tx != 1))
				rx = 1; tx = 0;
				//xil_printf("rx=1\n\r");
			if ((tx == 1) || (rx == 1))
				cbus_handler(dataread & 0xFF, &gpio2, &cbusflags, &tx, &rx, &gpo2);
				//xil_printf("cbus\n\r");
	dataread_before = dataread;
    XIntc_Acknowledge(&int_con,int_cbus_id);
void initialise_check(char str[],
				u8 status)
	if (~status)
	{	xil_printf(" %20s - successful\n\r", str);	}
	else  {xil_printf(" %25s - ERROR\n\r", str); }
	xil_printf("-----------------------------------\n\r");
