Visitor imran_123
Problem with Example Design- Using AXI DMA in polled mode to transfer data to memory
Hello All, I am trying to implement "Example Design- Using AXI DMA in polled mode to transfer data to memory" given at https://www.xilinx.com/support/answers/57561.html , i got the zynq based system in vivado 2016.2 and i upgraded to vivado 2016.4. but i got errors in SDK part
and also xgpio.h is not available in BSP includes
 please help me to remove the errors
thanks
regards
Imran
Tags (5)
Scholar hbucher
Re: Problem with Example Design- Using AXI DMA in polled mode to transfer data to memory
@imran_123
xgpio.h is generated automatically for you - but only if you add a GPIO to your block design.
Visitor imran_123
Thanks Henry Bucher
 i did what you told me, xgpio.h error is gone but some new error appears.
../src/helloworld.c:35:21: fatal error: xllfifo.h: No such file or directory
#include "xllfifo.h"
compilation terminated.
make: *** [src/helloworld.o] Error 1
Scholar hbucher
@imran_123
Same thing. It is only added when you add an AXI Stream Fifo to your board design.
Visitor imran_123
it is already there in board design given by this answer record
Scholar hbucher
@imran_123 That is a "AXI Stream Data FIFO". You need a "AXI-Stream FIFO".
The first is stream-stream. The one you need is memory mapped-stream.
