Visitor hassan.anwar
SEM IP core integration to a design on Zedboard
I want to perform fault injection into a design on a zedboard. From what I understand, I would have to add a sem core ip to the design. I need to ask the following :
1. Is there any tutorial for adding the sem core ip to a custom design and performing the injection?
2. The sem core is connected via the USB on the zedboard?
3. How can I find the addresses (of the frames) I want to inject the errors to? I want to inject errors into my design and not into the sem core itself.
Scholar pratham
Re: SEM IP core integration to a design on Zedboard
@hassan.anwar This will help you
http://www.xilinx.com/support/documentation/ip_documentation/sem/v4_1/pg036_sem.pdf
-Pratham
Observer namangov
Hi Pratham,
From what I understand, I would need to create a wrapper to provide connectivity between the SEM core and UART. I also looked at http://forums.xilinx.com/t5/Zynq-All-Programmable-SoC/SEM-IP-Zynq-Devices/td-p/590798
Can you shed some light on what needs to be done.
