Serial Terminal crash -SDK
I run hello world tutorial on xsdk 2015.2
"Failed to write core dump. Core dumps have been disabled. try "ulimit -c unlimited" before starting Java again"
Please help
ulimit -c unlimited ==> command not found
It is somehow similar to https://forums.xilinx.com/t5/Embedded-Development-Tools/2014-2-XSDK-Serial-Terminal-Crashing-SDK/m-p/525291/highlight/false#M33221
Thank you
Re: Serial Terminal crash -SDK
This can occur if the file handle limit is set too low to launch the blocksets in sdk.
To increase this, you can use the UNIX command ulimit, for example, "ulimit -n 1024" or "ulimit -n unlimited".
Thanks and Regards
Balkrishan
To solve this issue, put this line:
org.eclipse.swt.browser.DefaultType=mozilla
at the end of this file
eclipse/configuration/config.ini
and it'll work fine !!
Praveen
