Observer luckzzylb
The connection of VCCO and I/O pins of an unused I/O bank in Zynq UltraScale+ MPSoCs
According to xtp427, all VCCO and I/O pins of an unused IO banks should be connected together to GND, a valid VCCO voltage, or a floating plane for maximum ESD protection.
However, in AR# 11906, it says:
So, does it mean the unused I/O pins and VCCO pins in the inner rows of the pin array can be left floating because the ESD events are unlikely and not considered a high risk?
For example, if bank65 and bank66 are unused, can we connect the outermost pins (the pins in the red frame) of these two banks to ground and leave the remaining pins (including VCCO pins ) of these two banks floating?
Community Manager
Community Manager
Re: The connection of VCCO and I/O pins of an unused I/O bank in Zynq UltraScale+ MPSoCs
@luckzzylb If you don't plan on using the Bank, have the VCCO pins connected to GND or floating plane in case you can't connect all IO pins to GND. I/O pins can be left floating.
Each IO Pin has a upper clamp diode to VCCO and so by connecting VCCO to GND/floating plane, you are providing a path from the IO pin in case of an event.
- Giri
There's no such thing as a stupid question. Feel free to ask but do a quick search to make sure it ain't already answered.
Keep conversing, give Kudos and Accept Solution when you get one.
Community Manager
Community Manager
- Giri
Voyager
Voyager
Hey @luckzzylb,
That is how I'd interpret the "However ..." part, yes.
... can we connect the outermost pins to ground and leave the remaining pins floating?
I'd say that is what the "However ..." section implies.
But I wonder why you would want to do that in the first place instead of simply connecting them all together in a ground fill?
Best,
Herbert
-------------- Yes, I do this for fun!
