Two Controller SPI Test Setup
I have two SPI controller pinned out to PMOD pins on my ZCU102. Let's assume my hardware is correct for the time being. I have one SPI master and one SPI slave, both of which are pinned out of my PMOD. How can I do a polled transfer between the two? I want to send data from Master -> Slave -> Master just for validation purposes.
I am doing this in bare metal. Is it possible to do tasking? Do I need a task per controller so I can actively poll on both controllers at the same time? I have seen the spips examples and am going through them now.
I really appreciate any advice.
Re: Two Controller SPI Test Setup
Hi @doverstreet6 ,
You can make the four spi signals are out(MISO, MOSI, SS, sclk) from PS SPI controllers and make the external loop back to both of them and you can refer below forum thread for reference for loopback test.
https://forums.xilinx.com/t5/Embedded-Development-Tools/how-to-SDK-SPI-external-loopback-test/td-p/782665
Best Regards
Kranthi
Hi @doverstreet6 ,
Best Regards
Kranthi
