Observer mxdsgnl
Vivado 2018.3 IRQ_F2P mapping
I have interrupts connected to the IRQ_F2P port in my ip integrator design:
The dialog box in the zynq config states that the MSB (Bit 15) should be assigned to 91.  According to this, the LSB (Bit 0) should be assigned to IRQ 61.  The BSP generation script that produces xparameters.h maps these backward as shown in the picture.  I have verified in the SDK that the the interrupt through bit 0 is handled at vector 61.  However, the SDK script connects them as shown in purple below....
This did not happen in 2017.4.  Current work around is to override these #define literals.  However, this should be fixed in the script generation.  Would you please submit a problem report?
Nick
Observer mxdsgnl
Re: Vivado 2018.3 IRQ_F2P mapping
I noticed that I wrote 2018.3.  However, this is occuring in 2018.2.
Hi @mxdsgnl ,
Please share your block design bd.tcl file to replicate the issue and if it occurs in 2018.3 I may have to file request.
Praveen
