Visitor chesh
Vivado block diagram: signal to a bus
Very basic question, but I could not find it on google.
I'm upgrading from Vivado 2015.2 to 2015.4 and I'm having a error when I verify my design.
The error is on signal in my blockdiagram which goes from a signal to a bus of 1 bit wide (so a std_logic to std_logic_vector reset_n to reset_n[0:0]
I know I have to use the slice IP to change from a bus to a signal but what to use the other way around?
This issue appear between my ps_subsystem which gives an std_logic and my own reset controller which expects a std_logic_vector[0:0]
Re: Vivado block diagram: signal to a bus
Can you see if concat ip helps you?
-Shreays
Try to search answer for your issue in forums or xilinx user guides before you post a new thread.
Kindly note- Please mark the Answer as "Accept as solution" if information provided solves your query.
Give Kudos (star provided in right) to a post which you think is helpful and reply oriented.
-Shreays
Visitor chesh
I have tried this and still my design gave an error with verify design.
I re-opened the design again to put a screenshot in the forum, and I click Verify Design again and now it works!
So this solved the problem! Great thanks!
I have noticed this before, that sometimes the verify design still gave errors but after closing Vivido and opening again it is OK.
