Newbie fumikon
Writing data to slv_regs (AXI) from PL
I have a custom AXI peripheral, and accessing AXI registers (slv_regX) through software can be as easy as reading/writing memory addresses, no problems here.
Reading them from PL is also a direct operation (myport <= slv_reg0 for example), but... what about writing data to them? Doing something like "slv_reg0 <= myport" seems totally inadequate, and, in fact, triggers a lot of critical warning because of multi-driven  nets. So, what I'm asking is... what is the proper way to write data to these registers?
Visitor wittlage
Re: Writing data to slv_regs (AXI) from PL
Some ideas:
1.
You could make some of the registers read-only for the AXI interface by editing the process that is writing to the slv_regX signals.
2.
If you really need write access from PL and from the AXI interface, you will need some logic to resolve concurrent accesses from PL and AXI. You could add set_signalX and reset_signalX ports to the user ports section.
Visitor wittlage
Some ideas:
1.
2.
Newbie fumikon
The first idea is simple and effective.
Thanks a lot.
