Zynq : MIO pin mapping, pin 12 problem
We are using Vivado 2013.4 with xc7z030ffg676-2 chip.
We use parallel NOR flash via MIO interface. According to TRM UG585 table 2-4 there is “hole” in NOR flash MIO mapping in pins 12 and 14. However we cannot use MIO pin 12 as GPIO pin in processing system peripheral I/P pins MIO/EMIO selection.  Either we cannot select it or we have conflict with parallel NOR flash when e.g. selecting Ethernet reset to MIO pin 12. In Vivado there seems to be some "wait" input for parallel NOR flash Zynq connection in pin MIO(12).....
Ville-Veikko
Re: Zynq : MIO pin mapping, pin 12 problem
I got answer from Xilinx expert. TRM UG585 is correct, MIO pin 12 should be used as GPIO  when parallel NOR flash is used.  This is issue with the Vivado tool.
Ville-Veikko
