Zynq Standby mode
I use a Zedboard and I would like put the zynq in a standby mode (page 110 : http://www.xilinx.com/support/documentation/user_guides/ug585-Zynq-7000-TRM.pdf) but I don't know how I can do this. I use Xilinx SDK for program Zynq.
Have you got any examples ?
Jo
Scholar trenz-al
Re: Zynq Standby mode
just do it, where is the problem?
Yes but how ?
What is the function in C for put the proceesor in standby mode ?
Jo
Scholar trenz-al
c is a standard for an formal language.
c knows nothing about zynq or standby, hence there is no function in c that does it.
you need to write it.
Yes I know but Xilinx SDK generate many librairies for using the zynq and it don't have a lib for do that ?
In the UG585 (page 110) it say that it is necessary to set some bits in the mpcore.SCU_CONTROL_REGISTER for put the zynq in standby mode but which bit and how ?
I am new user with Zynq and ARM processor, where I can find the description of differents registers in the ARM processor ?
Jo
Scholar trenz-al
read Zynq TRM it must be described there.
I follow this step :
Enter Sleep Mode
A CPU must execute the following steps to enter sleep mode from normal run mode:
1.Disable interrupts. Execute cpsid if.
2.Configure wake-up device.
3.Enable L2 cache dynamic clock gating. Set l2cpl310.reg15_power_ctrl[dynamic_clk_gating_en]=1.
4.Enable SCU standby mode. Set mpcore.SCU_CONTROL_REGISTER[SCU_standby_enable] = 1.
5.Enable topswitch clock stop. Set slcr.TOPSW_CLK_CTRL[CLK_DIS] = 1.
6.Enable Cortex-A9 dynamic clock gating. Set cp15.power_control_register[dynamic_clock_gating] =1.
7.Put the external DDR memory into self-refresh mode. Refer to section 10.9.6 DDR Power Reduction
8.Put the PLLs into bypass mode. Set slcr.{ARM, DDR, IO}_PLL_CTRL[PLL_BYPASS_FORCE] = 1.
9.Shut down the PLLs. Set slcr.{ARM, DDR, IO}_PLL_CTRL[PLL_PWRDWN] = 1.
10.Increase the clock divisor to slow down the CPU clock. Set slcr.ARM_CLK_CTRL[DIVISOR] = 0x3f
11.Execute the wfi instruction to enter WFI mode.
Exit Sleep Mode
To exit from sleep mode:
1.Restore CPU clock divisor setting. Set slcr.ARM_CLK_CTRL[DIVISOR] = <original value>.
2.Power on the PLLs. Set slcr.{ARM, DDR, IO}_PLL_CTRL[PLL_PWRDWN] = 0.
3.Wait for PLL power-on and lock. Wait for slcr.PLL_STATUS[{ARM, DDR, IO}_PLL_LOCK] == 1.
4.Disable PLL bypass mode. Set slcr.{ARM, DDR, IO}_PLL_CTRL[PLL_BYPASS_FORCE] = 0.
5.Disable L2 cache dynamic clock gating. Set l2cpl310.reg15_power_ctrl[dynamic_clk_gating_en]=0.
6.Disable SCU standby mode. Set mpcore.SCU_CONTROL_REGISTER[SCU_standby_enable] = 0.
7.Disable Interconnect clock stop. Set slcr.TOPSW_CLK_CTRL[CLK_DIS] = 0.
8.Disable Cortex-A9 dynamic clock gating. Set cp15.power_control_register[dynamic_clock_gating] =0.
9. Enable all required peripheral devices, including DDR controller clocks.
10.Re-enable and serve interrupts. Execute cpsie if.
In the Xilinx SDK, all registers are unknows.
Visitor linh20111789
YOU RIGHT
Enter Sleep Mode
Exit Sleep Mode
