Visitor s.odekerken
10/100/100Mb Ethernet MAC signals
I am developing with the TEMAC core for some time and have implemented a design in a Spartan-3A 1400 on a custom board. I have set the unicast address according the user guide. If I stream data to the TEMAC, then I can see the data passing through the MAC and the clock enable signals are generated correctly, but the "emacclientrxdvld" signal remains low all the time. Also the "emacclientrxstatsvld" signal doesn't change it's state and remains low.
As an example design I have used the "temac_core_block.vhd" and lower which is generated by coregen.
Why don't these signals change their state? Am I missing some code?
Regards, Sander
Visitor s.odekerken
Re: 10/100/100Mb Ethernet MAC signals
How do I connect the TEMAC to get the signal emacclientrxdvld change to a valid data stream? I think that I did something wrong with the tieemacunicastaddr signal. How exactly does this vector look like with respect to a MAC address of C0-ED-BE-EF-CA-FE? I thought it was FE-CA-EF-BE-ED-C0. Is this correct?
What else could be the problem for not receiving valid data?
Thanks! Sander
Newbie pannian
Thanks for sharing!
@s.odekerken wrote:
Regards, Sander
Observer annand
As far as the 'tiemacunicastaddr' signal is concerned, what you gave is correct.
But please make sure that the 'Destination Address' field in the received frame contains the same MAC address as the address filter.
