1000Base-KX using Zynq UltraScale+
After reading several posts on this topic, I am still thoroughly confused.  I am trying to make a schematic to connect a Zynq UltraScale+ EV to a VPX switch card via 1000Base-KX.  I actually need 2 1000Base-KX connections to the switch card and 1 1000BaseT to PS.  Questions are:
1.  What IP do I need in my project, if any?
2.  What special settings do I need to change for PetaLinux if any?  Does auto-negotiation work?
3.  Will I use the GEM interface over EMIO to the PS or some other interface and what needs to be configured in Vivado?
Andrew
Re: 1000Base-KX using Zynq UltraScale+
XAPP 1305 application note focuses on ethernet-based designs that use Zynq UltraScale+ devices, this may help you
https://www.xilinx.com/support/documentation/application_notes/xapp1305-ps-pl-based-ethernet-solution.pdf
Pratap
Please mark the Answer as "Accept as solution" if information provided is helpful.
I have thoroughly read the XApp1305 and understand most of it now.  There is no mention of 1000Base-KX in any Xilinx documentation.  1000BaseX is mentioned.  Do I need to disable auto-negotiation?  I have settled on using the PS-PL over EMIO to the pcs_pma IP to a GTH port.
Bumping this threat. Would be great with these questions answered. XAPP1305 is not related to backplane Ethernet.
@rpr
1000Base-kx mode is not documented in XAPP1305, does this mean it's not supported? Is there anything that can be done to add support for this mode of operation?
Shant
