100G CMAC zcu111 - example design
I am trying to make the 100G CMAC RX design example to work on zcu111.
Connected the ref clock to USER_MGT_SI570 (156.25MHz) and the free running (init clock) to CLK_100 (100MHz).
I can not get the receiver up and running, the GT locks but then stat_rx_local_fault and stat_rx_internal_local_fault keep high.
I have tried to read statistics registers STAT_RX_BLOCK_LOCK_REG, STAT_RX_LANE_SYNC_ERR_REG, STAT_RX_LANE_SYNC_REG, STAT_RX_STATUS_REG, STAT_STATUS_REG1.
but I cannot get any meaningful information. All the values I read are 0x0C (defaulting to 0xfffff).
Could someone please provide some pointers?
any pointers on that?
Some ideas to try:
- Enable internal near end PMA loopback and/or external see if that allows link up
- Assert and de-assert gt_reset_all and then gt_rx_reset to see if this allows link up
Also be aware that some of the status registers are latching and require reading twice to get the latest status.
Thank you very much for your reply,
I have changed loopback modes, with not effect (even though that worked in the TX).
I have also persisted with reset, but I'll give it another go.
I am doing reading more than once, the first I get 0x0c the second 0xfffff (which as I understand is the register defaulting to 1?)
@ejanney
Could you please let me know if by gt_reset_all  you mean gtwiz_reset_all_in and by gt_rx_reset gt_wiz_reset_rx_datapath_in?
@ejanney
Can I please ask if there is any other alternative?
Please bear in mind I am working with the generated example design.
Yes this is correct:
@ejanney Thank you very much for your reply,
I have been experiencing problems due to the following:
The stat_rx_synced is mostly FFFEE resulting from stat_rx_mf_len_err being 00011.
Would you be able to provide some feedback?
