100G rx_alignment on Post Synthesis functional simulation
I'm trying to simulate a US+ 2019.1 100G xilinx IP, I have a custom design:
1) board kcu116
2) clock for init_clk 125Mz
3) CAUI-4 with 161.1328 MHz for gt clk
4) AXI stream and AXi4-Lite to control rx_alignment from CMAC internal register
5) testbench in which I connect gt_rx/tx port in loopback
In Behavioural simulation I have no problem and I can see alignment and the packet trasmitted form AXI Stream Tx port that arrives to Rx of CMAC.
Instead If I run simulation after Post Synthesis, both Functional and Timing simulation I don't get the alignment, I tried for 1ms of simulation.
The same happens with an example design project of CMAC provide by Xilinx, the behavioural works but after synthesis it doesn't get the alignment.
Have I to wait more time in the simulation?
Is there a start-up timing to wait after the boats is powered on?
I release reset in this sequence:
1) release reset for cmac sys:reset
2) release reset for both gt:rx and gt_tx path at the same time
3) then I release reset of control logic
the control logic wait to poll the cmac on axi4-lite port for about 30us the starts.
I don't know if the 2 thinks are related, however the design havven't any timing issue on timing summary.
Thank you!
回复: 100G rx_alignment on Post Synthesis functional simulation
Have you set "-d SIM_SPEED_UP"?
Do you enable RSFEC?
Re: 100G rx_alignment on Post Synthesis functional simulation
HI @namabo
As I understood from your description about simulation: Behaviour simulation with SIM_SPEED_UP applied will take less time than the Post synthesis simulation.Hardware testing will take the time equivalent to Post synthesis simulation for the rx_alignment. As I simulated some time back it takes about 1.683ms to get rx_alignment.
If you beleive the funcitonal simulation takes even more than this time for your custom design we can think of resets.Please share your simualtion screens.
Hi @kgadde,
I confirm you that example design converges in 1.6 ms to rx_alignment in Post functional simulation.
@kgadde,
I'm trying to simulate the post-functional with RS-FEC on the example design It takes a lot of time for now I'm at 2.5ms (about 7h).
I will let you know.
Thank you for your support guys.
I finished the simulation on the example design and
after 10ms it doesn't reach the alignment yet, it ends with the following errors:
ERROR : Rx_Aligned failed - Time Out Error
ERROR : Time Out Error
Now, these are the first experiment I do with post synth and post impl simulation, in my design I skept this point because I preferred to go in the real hardware with ILA or System ILA.
I extend the thread and I would like to know your personal approach:
Do you perform all the simulation steps in a project or do you prefer to consider just the behavioural sim or simulation subset? If so which subset do you use?
The simulation time is very high, 3/4hours for post-synthesis, I didn't try the post implementation but I think it could easly reach one day of simulation.
Thank you
