10G Ethernet on RFSoC Devices
Is it possible to have 10G ethernet on RFSoC devices. I am planning to use XCZU28DR device. Is there any IP core to support 10G ethernet for this device?
Hello @Sumanta
RFSoC has a similar fabric architecture compared to other UltraScale+ devices. GTY architecture is the same for UltraScale+ devices.
I can confirm using Vivado 2019.2 that "10G/25G High Speed Ethernet Subsystem v3.1" can be generated without any issue.
I will ask Ethernet/Document team to add RFSoC for supported device for next PG210 document update.
Leo
Hello @Sumanta
Yes, the following 10G Ethernet IP can be used with UltraScale+ GTY.
https://www.xilinx.com/support/documentation/ip_documentation/xxv_ethernet/v3_1/pg210-25g-ethernet.pdf
You need to get an evaluation license for this IP to use it on your HW.
Leo
Hi Karnanl,
The supported device family is showing as
Zynq® UltraScale+™ MPSoC,
Virtex® UltraScale+™,
Kintex® UltraScale+™
Virtex® UltraScale™,
Kintex UltraScale
There is no mention about RFSoC Devices. Can you please clarify?
Hello @Sumanta
Leo
Thank You very much Leo.
