Voyager
Voyager
10G base pcs/pma IP question
does the Xilinx 10G base pcs/pma has retimer?  I need 4x of 10G for QSFP+, which is in XLPPI,  but not sure if the 4x 10G base ip is compatible with QSFP+ XLPPI
Re: 10G base pcs/pma IP question
10G base pcs/pma  core doesn't have any re timers.
For 40G application you can use below core
https://www.xilinx.com/products/intellectual-property/ef-di-50gemac.html
Satish
