25G Ethernet on Zynq UltraScale+ FPGA (GTY transceiver is not working)
I am using XCZU19EGFFVD1760 FPGA board, and I am checking the 25G Ethernet Speed on Zynq UltraScale+ board with QSFP but GTY transceiver is not working.
In  10G/25G Ethernet Subsytem IP, I have set the GT selection and configuration according to the documents.
What could be the problem ? Anyone can suggest please
Speed : 25G
Enabled : 4 Cores
GT Selection and Configuration : GTY , Clock : 322.265 MHZ.
Eth25_1.pngGT ConfigGT ConfigRX Window is inactiveRX Window is inactive
回复: 25G Ethernet on Zynq UltraScale+ FPGA (GTY transceiver is not working)
Is this for simulation?
Please try IP core example design first.
And add "-d SIM_SPEED_UP" to speed up the simulation
Can you see data in simulation?
>>>>Is this for simulation?           NO
After generating bitstream and dupping the .bit file into hardware. Then checking the output in ILA.
Still you can try IP core example design with near end loopback mode first.
You can also run IBERT first to confirm that GTY HW environment is good.
Any link please :(
Right click on the IP core .xci file in Vivado project and select "generate IP core example design"
Hi @thaus_015 ,
Also, please refer to page 20 for further detail of IBERT example design in  https://www.xilinx.com/support/documentation/ip_documentation/ibert_ultrascale_gty/v1_3/pg196-ibert-ultrascale-gty.pdf.
Praveen
