csommer
AXI Ethernet SGMII 125MHz differential clock input
I am integrating the AXI 1G/2.5G Ethernet IP on a Zynq 7020 living on a custom-made board to interact with an external Marvell 88E1512 PHY over SGMII.
The 1G/2.5G Ethernet PCS/PMA IP included in the core of the AXI Ethernet IP requires a 125 MHz differential clock.
The 88E1512 has a 125 MHz single ended clock output synchronized with its 25 MHz reference clock.
Do I need to use that 125 MHz output from the PHY for the Ethernet IP in the Zynq to work properly?
Or is it okay to use another external differential crystal oscillator that is not sync'd with the PHY?
nanz
Hi @csommer ,
It's ok to use an external differential crystal oscillator for the IP.
I would recommend to look at PG047 for clocking details:
https://www.xilinx.com/support/documentation/ip_documentation/gig_eth_pcs_pma/v13_0/pg047-gig-eth-pcs-pma.pdf
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs and our Versal Ethernet Sticky Note.
nanz
Hi @csommer ,
csommer
Hi @nanz,
Thanks a lot for your quick reply, it's clear now.
I don't see an easy way to use the single ended clock output of the PHY with the differential clock input of the IP.
So my best bet here is to use Figure 6-1 implementation you shared from PG047.
