nishihara
About SGMII Operation with AXI 1G/2.5G Ethernet Subsystem
Hello
I want to use the AXI 1G/2.5G Ethernet Subsystem for UDP communication.
We ran a simulation and found that SGMII in TX data
It doesn't change.
I was checking the difference between the ethernet subsystem demo data and the ethernet subsystem demo data, but it seems to be working up to gmii_txd being input to the internal PCS.
From there, what is happening during the conversion to sgmii?
nishihara
Thanks for the answer.
Self-resolved.
I made a mistake in setting the access register to MDIO, and I was able to confirm that txdata transitions to something other than IDLE by returning it successfully.
Sorry for the simple mistake.
nanz
Hi @nishihara ,
I am not sure if I understand what your exact questions are.
Do you ask about SGMII simulation that does not work or how SGMII works in general? Please be more specific on your questions. What is your expectation in simulation?
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs and our Versal Ethernet Sticky Note.
guozhenp
The 1st screenshot has the packet data on "txdata[7:0]" while the 2nd one only has IDLE (BC50) on "txdata[7:0]"?
Is this the question?
Does SGMII get link up first, e.g. checking SGMII "status_vector"?
nishihara
I am running a simulation with TX output connected to RX. status_vector changes from x020b to x0203. (This is equivalent to the demo simulation).
nishihara
Sorry for the vague question.
We are checking the operation through simulation, but there is no change in the output from the IP, so I am asking this question.
When I input data into the TX port of the Ethernet subsystem, the output is a fixed value (IDLE?).
The first screenshot is a sample simulation result and the second is the actual simulation result of running it.
We analyzed the internals and it seems to be working up to GMII, but
sgmii does not seem to be working. Is there any cause?
guozhenp
Need to see all the inputs, outputs signals of the SGMII IP core, e.g. configuration_vector, signal_detect ...
You can also compare them against those in the example design.
nishihara
Self-resolved.
