Aurora microblaze design
I am implementing Microblaze based aurora 8b10b design(SFP) simplex.
Kintex 7 custom board- TX (Microblaze based design- inputs given from externally to aurora)
KC705 - RX
In receiver side how do I verify the signals in frame checker part? Should I assign the same signal which is transmitted in Tx side?
If my Tx signal is time varying, How do I verify?
Any reference design for Microblaze based design?
Abinaya
Re: Aurora microblaze design
Check the m_axi_rx_tvalid,maxi_rx_tdata  and m_axi_tlast signals @ aurora rx end.
