Aurora v11 simplex backchannel with timer
We are currently on aurora design with a 1CH simplex TX and a 1CHsimplex RX core. Also we have a slow serial backchannel a few µs delay.
Now we consider using the "Timer" backchannel because it would be easier to use.
Would you recommend the Timer method?
pg046 says: "The timers must be designed carefully to meet the needs ..."
But we can not find how these timers are calculated.
Best regards,
Wolfgang
Re: Aurora v11 simplex backchannel with timer
Can you apply the reset sequence mentioned in the PG046 manually through VIO? Check if the channel up is acheived.
If you follow the sequence as mentioned in PG046 where tx_reset is released as the last event in the sequence, timer adjustment may not be required.
