BUG:Tri mode Ethernet MAC 9.0 r13 - TX PTP Packet Buffer write data corruption
The problem bellow is not fixed in Vivado 2018.3.
https://forums.xilinx.com/t5/Networking-and-Connectivity/BUG-Tri-mode-Ethernet-MAC-9-0-r12-TX-PTP-Packet-Buffer-write/td-p/884772
No AR about this problem exists.
Does Xilinx recognize this problem?
Re: BUG:Tri mode Ethernet MAC 9.0 r13 - TX PTP Packet Buffer write data corruption
Hi @windypon
I have checked internally, already change request made on this request.
Currently dev team working on this, issue will be fixed is vivado 2019.1
Pratap
Please mark the Answer as "Accept as solution" if information provided is helpful.
Hi @windypon
Pratap
Thank you.
I must be waiting for 2019.1
This probrem has been fixed on 2019.1
