RuashTime
Changing loopback mode of GT in MRMAC
I am trying to do Near-end PMA loopback on MRMAC. As MRMAC doesn't provide direct port to configure it, I output a signal from cips to control the SW_REG_GT_LOOPBACK in PL. But then the timing constraints won't meet.
So do you have some good solutions to control the loopback mode in MRMAC?
Tags (2)
RuashTime
Hi @nanz
I already forgot this question haha. It has been solved. Timing has no problems now.
nanz
Hi @RuashTime ,
The loopback should not impact timing I believe. Do you have more details regarding this?
Is this related to pma near-end loopback question you ask in another thread/SR?
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs and our Versal Ethernet Sticky Note.
RuashTime
Hi @nanz
nanz
Hi @RuashTime ,
It's great to hear. Could you please update it with your solution and mark it as "accepted solution"? So it will benefit other forum users too. Thank you!
