Data transfer with Ethernet cable using Zybo z7-10
I use the Zybo Z7-10 card in my project. In my project, which I'm currently dealing with, I get the noise added to the noise thanks to Matlab. Then I try to send the image to the ARM part of the card via the ethernet cable. Can I send the information I received from matlab using the sample lwIP echo server application in the SDK? Is there anyone who has tried this? If there is any help, I would be very happy.
Re: Data transfer with Ethernet cable using Zybo z7-10
Hi @ekin_oks ,
lwIP echo application is a simple application which will just echo anything back to the host.  So it probably won't do the job for you.
Please check tftp and webserver application from XAPP1026 to see if it helps.
https://www.xilinx.com/support/documentation/application_notes/xapp1026.pdf
"Don't forget to reply, kudo and accept as solution."
Hi @ekin_oks ,
