Observer sridevi123
Does Zynq(7045) MIO support MII PHY ethernet(TI's DP83848)
I am working on ZYNQ(7045) based custom Board. Ethernet (DP83848) is interfaced to zynq through MIO lines. Configured as MII.  I  am testing ethernet using Lwip echo server in SDK. I get the following print once I run lwip echo server.
-----lwIP TCP echo server ------
TCP packets sent to port 6001 will be echoed back
link speed for phy address 0: 100
DHCP Timeout
Configuring default IP of 192.168.1.10
Board IP: 192.168.1.10
Netmask : 255.255.255.0
Gateway : 192.168.1.1
TCP echo server started @ port 7
But when I try to ping  from PC I get destination host unreachable.
and when I checked  RX_DV/MII_MODE  during reset is high (should be low for MII). Is lwip echo server support DP83848?.
Please help me.
Thank you
Sridevi
Re: Does Zynq(7045) MIO support MII PHY ethernet(TI's DP83848)
Hi @sridevi123
MIO Peripheral Interface supports RGMII interface, please refer to following figure
Pratap
Please mark the Answer as "Accept as solution" if information provided is helpful.
