elenp
Don't work Aurora 8B/10B core not including shared logic
I have a question about Aurora 8B/10B.
I refer to figure 3-11 of Aurora 8B/10B product guide PG046 and four Aurora are connected on the block design,
only cores with [include Shared Logic in core] enabled will work, and the other three cores will not work.
The operation confirmation was done by using the sample design FRAME_GEN and FARME_CHECK and making it internal loop back.
It is operating normally in simulation.
The development environment is as follows.
* OS : Ubuntu 16.04 LTS
* Tool : Vivado 2016.2(64bit)
* Device : xc7a50tcsg325-2
The settings of Aurora are as follows.
[Core Options]
* 6Lane Width : 4
* Line Rate : 6.25
* GT Refclk : 156.250
* INIT clk : 59.9994
* DRP clk : 59.9994
* Lanes : 1
* Dataflow Mode : Duplex
* Interface : Framing
* Flow Control : Completion NFC
* Scrambler/Descrambler : OFF
* Little Endian Support : OFF
* CRC : ON
* Additional transceiver control and status ports : OFF
* GT DRP Interface : OFF
[GT Selections]
* Lanes : 1
* GT Refclk1 : GTPQ0
[Shared Logic]
* include Shared Logic in core : ON(Only one core)
* include Shared Logic in example design : ON(The other three cores)
* Single Ended INIT CLK : ON(Only one core)
By the way, changing the Lane Width to 2 Byte all cores worked.
Those who understand the solution, please help me.
Thank you
venkata
You mention that "It is operating normally in the simulation". Is this applicable to 4-byte lane width setting also?
I believe the following should be done on all instances in which "* include Shared Logic in example design : ON" is set. Can you please confirm?
For 4-lane design, whether DRPCLK input is stable?
What do you observe on the following status signals?
rx_reset_done_out
tx_reset_done_out
tx_lock
sys_reset_out
soft_err
hard_err
link_reset_out
lane_up
channel_up
