ETH1 static IP link up and link down issue
Hello..
In my design i have two ethernet ports ETH0 and ETH1 . ETH0  is directly connected to PS through MIO interface . ETH1 is EMIO interface for the i connected gmii_to_rgmii IP core v.I am using gmii_to_rgmii IP core with KSZ9031rnx ethernet PHY device .  i assigned a static IP to the ETH1 in etc/int.d/networks file as static IP .When ever i turn on the device i am able to ping the ETH1 with my PC . If make ETH1 LINK DOWN and again if i make ETH1 LINK UP PING is not happening if i power off the board and power on ping is working . Please help me with this ?
nanz
Hi tnareshnaresh7@gmail.com ,
Your issue seems very similar to this one:
https://forums.xilinx.com/t5/Ethernet/Dual-Ethernet-Switching-problem-in-static-configuration/td-p/1196526
Please can you check?
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs and our Versal Ethernet Sticky Note.
