Echo server application not running in Zedboard
I am trying to run the Echo server application in Zedboard. When the application is not running, I can easily ping my zedboard with the ip address 192.168.1.10. Consequently the echo server is also running. But whenever I am building my application and running it (Run as-> launch on hardware GDB), I cannot ping the same. It says destination host unreachable. The serial terminal shows echo server started at port 7. But when I am trying to connect using the ip address and port no 7 the connection drops.
I cannot understand what is wrong. Any advice? Please.
Hi @tish ,
Is that thread same with yours? One of them is Zedboard user and he said: "I'm living same problem."
Saban
<--- If reply is helpful, please feel free to give Kudos, and close if it answers your question --->
Hi @sabankocal
Yes. Kind of same. But that thread has given a solution to a different problem. It is related to the PHY chip. Realtek or Marvell. But I am not sure whether my problem has the same solution as that thread.
Any other solution or advice please?
