Ethernet MAC IP core license
Hi Everybody,
       I'm using virtex 4 fx device xc4vfx100-10ff1152 device. I'm trying to use Embedded trimode ethernet MAC core using ISE 9.2i, but  I'm unable to find HDL functional model.
        I tried the same using Trimode Ethernet MAC core, I'm able to find the HDL functional model. To generate the bit file it requires license. I have downloaded the license. How to install the license in ISE 9.2i?
        When I'm using the EDK there is an Ethernet core which rquires the license to be purchased ?.
        For using the Ethernet core ( Embedded trimode ethernet MAC or  Trimode ethernet MAC) in XC4VFX100-10FF1152 device does I need to purchase the license ?
There is an issue with the EDK version of embedded TEMAC which requires a license key and has been documented in AR32054. Customers can generate a license key at the link below.
 http://www.xilinx.com/member/xps_ll_temac_perpetual_eval/index.htm
