11-11-2019 08:07 AM
Hello all,
I am trying to implement the PTP using the GEM in the Zynq UltraScale architecture, but I have some questions related with this topic. My intention is to have a clock in the PL synchronous with the master clock that are sending the PTP. So my board is the slave, and there will be a master (potentialy will be a PC) that through PTP will send the timestamp. From this timestamp I need to recover or I need to create a clock synchronous to the master clock.
As far as I know the GEM implements PTP. In the Technical Reference Manual, I found the following figure:
So now I have the following questions:
1) How can I get a clock synchronous to the master clock?
2) Is there any way to change the PS frequency in order to be synchronized with the master clock, and from this frequency create a PL fabric clock synchronous with the master clock that be accessible from the PL?
3) Anybody has more information apart from the "GEM_TSU_Interface_Details"? In my opinion there are few information there, and I cannot follow the procedure to execute the PTP testing. 4) When enabling the PTP Interface, the PS adds a PTP interface that can be accessible from the PL. For which propose is this? Maybe the clock has to be reconstructed in the PL?
I would appreciate some help in this topic because I don't find useful information to find out the solution of my problem.
Thanks and best regards,
baldrism
11-15-2019 08:12 AM
Hi @baldrism ,
The TSU clock source can be from PLL or MIO and EMIO. The registers to look at are GEM_CLK_CTRL, TSU_REF_CLK_CTRL, and MIO_PIN_XX (in case of MIO).
When GEM0 is enabled, the 1PPS signal will be exposed to PL so users can sync their logics on PL by refering it.
11-15-2019 08:48 AM
Hello @nanz ,
Thank you very much for your reply.
I didn't find the PPS signal from the GEM, could you please show me where can I find it?
Moreover, how can I sync the PL clocks using the 1PPS signal? Is there any guide or XAPP that I could follow for that?
Thank you very much,
baldrism
11-19-2019 06:20 AM
Hi @baldrism ,
That is the tsu_timer_cnt signal that I meat.
11-19-2019 06:34 AM - edited 11-19-2019 06:35 AM
Thank you @nanz ,
Do you know how can I create a synchronous clock in the PL using the PPS signal? I need to generate 2MHz synchronous with the master clock and I don't know if it is feasible or not.
Best regards,
baldrism
11-19-2019 07:12 AM
Hi @baldrism ,
I believe you should be able to do this by creating a custom IP on PL with taking the tsu_timer_cnt value and 1PPS signal into processing.
Unfortunately, we do not have an example of doing it.
