04-29-2020 03:05 AM
I have created a combinational design of HDMI In and Out + 10G.While implementation run , there is an error appearing . The error is as follows:
The design requires more GTE4_COMMON cells than that are available in the device . The design requires 2 such type cell while there is only 1 cell in the device . What can be done in tis case?
04-29-2020 03:37 AM
Hi @Nireeksha
You can purchase a device that has more (multi)gigabit transceivers.
What is the device model?
04-29-2020 03:58 AM
The device is XCZU5ev-sfvc784E. I need to implement the design with this as the target device.
04-30-2020 01:16 AM
Hi @Nireeksha ,
Is it possible to use shared logic between two IPs? You can check by generating the core with shared logic in the example design.
