Visitor mansura
IBUFDS_GET4.O is locked to GTHE4_common_x0Y2 ZCU102 Dev Board
Hello Xilinx Folks
I am using a ZCU102 eval board to receive aurora data via the SFP port.
I am not sure what to set for the XY options on the Aurora IP. It is very confusing and the documentation is very limited as far as explaining what it means. In the documentation it shows this.
Image above is from Aurora Document for reference.
I am not sure how to find the corresponding locations for the SFP ports on the ZCU102 board. I am using SFP0 and SFP1. Below there is a snip of the schematic as well. How can I cross reference the Aurora 8b10b description as seen in PG046 with the ZCU102 eval board? How to find the proper properties for the Aurora IP as shown below highlighted.
Image above is from ZCU102 schematic for reference.
Image above is from Aurora GUI. not sure what to set for highlighted options.
Image above is the error I am getting. It is a critical warning that leads to a non rout able clock signal for the aurora.
Any help is appreciated.
Re: IBUFDS_GET4.O is locked to GTHE4_common_x0Y2 ZCU102 Dev Board
Based on ug1075, figure 1-15
I find Quad 230 on ZCU102 board has GT locations from X1Y12-X1Y15.
Visitor mansura
Hello
Can you point me to the document where that was found.
I am not sure I fully understand your question, here is the link to ug1075.
http://www.xilinx.com/support/documentation/user_guides/ug1075-zynq-ultrascale-pkg-pinout.pdf
Visitor mansura
That was what I was looking for, the document you reference to find the XY locations.
Thanks for the help.
