Visitor zhanneta
IEEE 1588 Timestamping on CMAC: Clock Cycle Jitter Removal
I am working with CMAC 2.6 in Xilinx Vivado 2019.1 and have a question regarding IEEE 1588 timestamping.
In the user guide, it isn't clear where "reference fill level" is from. The following formula is illustrated in the user guide:
corrected_timestamp = rx_ptp_tstamp_out + (Reference Fill Level - rx_lane_aligner_fill_0)
I understood the following:
1. rx_ptp_tstamp_out is a timestamp of the start of packet that needs to be corrected based on lane aligner fills to get rid of clock cycle jitter
2. rx_ptp_pcslane_out is used to choose one of the rx_lane_aligner_fill_* (example: rx_ptp_pcslane_out = 3 -> use rx_lane_aligner_fill_3)
3. rx_ptp_pcslane_out is used to determine the physical lane using stat_rx_pcsl_number_* (example: rx_ptp_pcslane_out = 5 and stat_rx_pcsl_number_7 = 5 -> start of packet received on physical lane 7)
4. use physical lane number to find out the "reference fill level" -> HOW?
5. use the formula to calculate the corrected timestamp
Can you please correct me in my assumptions and help me understand how to get the "reference fill level"?
Thank you,
Zhanneta
回复: IEEE 1588 Timestamping on CMAC: Clock Cycle Jitter Removal
OK. Here're the details.
rx_lane_aligner_fill_0 is "rx_lane_aligner_fill_0"  for the lane on which the timestamp was taken.
Reference Fill Level is "rx_lane_aligner_fill_X". "X" here is for the lane on which SOP was detected (RX_PTP_PCSLANE_OUT) and is translated by stat_rx_pcsl_number_*.
For example, if RX_PTP_PCSLANE_OUT is 5, the customer should go to check stat_rx_pcsl_number_5 first. And if stat_rx_pcsl_number_5 is 15, he can use rx_lane_aligner_fill_15 as the reference fill level to minus rx_lane_aligner_fill_0 and compensate the timestamp.
"Reference Fill Level" are CMAC outputs
Visitor zhanneta
I can't find "Reference Fill Level" among CMAC outputs. Can you please clarify?
Are you reading PG203? It lists as follows.
RX_LANE_ALIGNER_FILL_0[7-1:0]
O
RX_CLK
This output indicates the fill level of the alignment
buffer for PCS lane0. This information can be used
by the PTP application, together with the signal
RX_PTP_PCSLANE_OUT[4:0], to adjust for the lane
skew of the arriving SOP. The units are SerDes clock
cycles.
Visitor zhanneta
Yes, I am reading PG203. In the userguide, they share the following formula:
From the description and the formula, it seems like "Reference Fill Level" and "rx_lane_aligner_fill_*" are not the same. In the userguide, they also say the following:
"The reference fill level is the average fill level of the rx lane aligner fill after the PCS lane number carried by rx_ptp_pcslane_out is translated to a PMD lane number via the stat_rx_pcsl_number_*."
It seems like you are supposed to translate RX_PTP_PCSLANE_OUT into physical lane number and then get the reference fill level somehow.
Visitor zhanneta
Thank you, that clarifies it!
Visitor zhanneta
The problem is that in the datasheet these signals are defined as follows:
RX_PTP_PCSLANE_OUT = PCS lane where SOP was detected
STAT_RX_PCSL_NUMBER_X = indicates PCS lane received on physical lane X
RX_LANE_ALIGNER_FILL_X = indicates fill level of alignment buffer for PCS lane X
So, it doesn't make sense that we would have to translate RX_PTP_PCSLANE_OUT into physical lane because RX_LANE_ALIGNER_FILL_X is per PCS lane.
If what you are saying is true, the user guide has an error.
Should RX_LANE_ALIGNER_FILL_X be correspondant to physical lane (X = physical lane number)?
