JESD204 Simulation speed
Hello Xilinx World,
I am simulating 2 JESD204 IP (RX an TX) using vivado 2018.2.
The gt_reset_done signal goes high after around 2.3 ms, wich correspond to 15H of running simulation on my computer...
Is it possible to accelerate de simulation speed???
I know it was possible with some others IP by setting a PROPERTY to true before genrating the block design.
Thank you for your help.
Best regards
Re: JESD204 Simulation speed
Hi @mlefevre,
what device/GT are you actually using? Do you simulate with the GTs or just the JESD cores?
I am using GTYE4 on xcvu9p.
I am simulating with GTs (waiting for gt_reset_done).
I 'am simulating 2 block design :
  • 1 containing a 8 Lane jesd204 Rx core and a JESD204 phy
  • the others containing a 8 Lane jesd204 Tx core and a JESD204 phy
Both block design are connected together (SERDIN/SERDOUT and syncB) in a Test Bench to simulate the interface with a JESD204 ADC.
