JESD204 always reset state
I'm tried 'JESD204 Hardware Demo' in EVM(zc706) but it is not work
Reset register(0x004) is always '1'(reset state)
help me!
Can you post a screenshot of your ILA waveforms in the Hardware Manager?
What state did you tie reset to?  Typically reset = 1 to reset, 0 to run.
resetn is 0 to reset, and 1 to run....
Check you have the correct logic for this reset signal in your design.
Austin Lesea
Principal Engineer
Xilinx San Jose
I do not reset
This is Xilinx Demo Program(ZC706)
i don't touch Demo code
Have you tried to apply reset ‘vio_reset’ pushbutton in VIO (or) Left SW7 pushbutton on the board?
Please post the snapshot of the VIO console when you are testing.
