Visitor liquan456885
K7 GTX CDR setting
   we want to used the recommended CDR setting which advised by UG476 , however, based on the REFCLK PPM parameter, I do not know which I could choose. Could anybody told me how can I get the REFCLK PPM parameter? by the way, I used a 150MHz with 50PPM OSC for the external GTX reference clock source.Thanks.
Community Manager
Community Manager
Re: K7 GTX CDR setting
REFCLK PPM value is given in the datasheet of the oscillator that you use to supply the GTRELCLKs.
Since, the PPM spec of your oscillator is +/- 50 PPM, you can use the CDR setting given for +/- 200 PPM.
Krishna
      thanks for you kind help,Krishna. Is there any detail introduction for the 72 bit RXCDR_CFG? Thanks.
Community Manager
Community Manager
No, we don't have the bit description of RXCDR_CFG. User is intended to use values provided in the user guide.
Krishna
Observer prakashdrj
@smarell,
I am using custom protocol which has 0 to 5000 ppm downspreaded and +/-300 ppm of clock, How can I set RXCDR_CFG?
Prakash
If you check the kintex-7 data sheet - DS182, table 62. 5000ppm of down spread with 33khz modulation frequency is supported. If the SSC is outside this spec, the CDR is not characterized for this use case.
Observer prakashdrj
@venkata,
Agreed, it shown there. But if you can see UG476 not listed parameters for SSC having profile -5000 ppm? Isn't it?
How can we configure RXCDR_CFG for that?
Prakash
Please check AR#53364
http://www.xilinx.com/support/answers/53364.html
