tchin123
Missing Interrupt signal from ethernet IP system
I'm using the AXI-Ethernet subsystem PG138 and the Interrupt signal is not there on the instantiation block. I traverse down into the schematic and still it is not brought out.
I check the IP wizard while creating this device and there isn't any other there concerning Interrupt option.
Why is it not there and how can I resolve this?
tchin123
any comment or idea on why the Interrupt signal is not brought out of the AXI_Ethernet IP core (PG138)
nanz
Hi @tchin123 ,
What is the version of the IP you are using? Can you please share your XCI file?
tchin123
The IP version is 7.1.
Attached is the IP xci file as requested. Hopefully this would shine some light to why the Interrupt signal is not brought out for user. Can't attached xci file even after I change the .xci extension. Therefore it is shown below
<?xml version="1.0" encoding="UTF-8"?>
<spirit:design xmlns:xilinx="http://www.xilinx.com" xmlns:spirit="http://www.spiritconsortium.org/XMLSchema/SPIRIT/1685-2009" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<spirit:vendor>xilinx.com</spirit:vendor>
<spirit:library>xci</spirit:library>
<spirit:name>unknown</spirit:name>
<spirit:version>1.0</spirit:version>
<spirit:componentInstances>
<spirit:componentInstance>
<spirit:instanceName>axi_ethernet_0</spirit:instanceName>
<spirit:componentRef spirit:vendor="xilinx.com" spirit:library="ip" spirit:name="axi_ethernet" spirit:version="7.1"/>
<spirit:configurableElementValues>
<spirit:configurableElementValue spirit:referenceId="ADDRBLOCK_BASE_ADDRESS.S_AXI.Reg0">0x00000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.CLK.GTREF_CLK_OUT.ASSOCIATED_BUSIF"/>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.CLK.GTREF_CLK_OUT.ASSOCIATED_RESET"/>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.CLK.GTREF_CLK_OUT.CLK_DOMAIN">bd_5d9f_0_pcs_pma_0_gtrefclk_out</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.CLK.GTREF_CLK_OUT.FREQ_HZ">125000000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.CLK.GTREF_CLK_OUT.PHASE">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.CLK.REF_CLK.ASSOCIATED_BUSIF"/>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.CLK.REF_CLK.ASSOCIATED_RESET"/>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.CLK.REF_CLK.CLK_DOMAIN"/>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.CLK.REF_CLK.FREQ_HZ">100000000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.CLK.REF_CLK.PHASE">0.000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.CLK.RXUSERCLK2_OUT.ASSOCIATED_BUSIF"/>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.CLK.RXUSERCLK2_OUT.ASSOCIATED_RESET"/>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.CLK.RXUSERCLK2_OUT.CLK_DOMAIN">bd_5d9f_0_pcs_pma_0_rxuserclk2_out</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.CLK.RXUSERCLK2_OUT.FREQ_HZ">62500000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.CLK.RXUSERCLK2_OUT.PHASE">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.CLK.RXUSERCLK_OUT.ASSOCIATED_BUSIF"/>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.CLK.RXUSERCLK_OUT.ASSOCIATED_RESET"/>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.CLK.RXUSERCLK_OUT.CLK_DOMAIN">bd_5d9f_0_pcs_pma_0_rxuserclk_out</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.CLK.RXUSERCLK_OUT.FREQ_HZ">62500000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.CLK.RXUSERCLK_OUT.PHASE">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.CLK.RX_MAC_ACLK.ASSOCIATED_ASYNC_RESET"/>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.CLK.RX_MAC_ACLK.ASSOCIATED_BUSIF">m_axis_rx</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.CLK.RX_MAC_ACLK.ASSOCIATED_RESET">rx_reset</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.CLK.RX_MAC_ACLK.CLK_DOMAIN">bd_5d9f_0_pcs_pma_0_userclk2_out</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.CLK.RX_MAC_ACLK.FREQ_HZ">125000000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.CLK.RX_MAC_ACLK.PHASE">0.000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.CLK.S_AXI_LITE_CLK.ASSOCIATED_BUSIF">s_axi</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.CLK.S_AXI_LITE_CLK.ASSOCIATED_CLKEN">CE</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.CLK.S_AXI_LITE_CLK.ASSOCIATED_RESET">s_axi_lite_resetn</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.CLK.S_AXI_LITE_CLK.CLK_DOMAIN"/>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.CLK.S_AXI_LITE_CLK.FREQ_HZ">100000000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.CLK.S_AXI_LITE_CLK.PHASE">0.000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.CLK.TX_MAC_ACLK.ASSOCIATED_ASYNC_RESET"/>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.CLK.TX_MAC_ACLK.ASSOCIATED_BUSIF">s_axis_pause:s_axis_tx</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.CLK.TX_MAC_ACLK.ASSOCIATED_RESET">tx_reset</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.CLK.TX_MAC_ACLK.CLK_DOMAIN">bd_5d9f_0_pcs_pma_0_userclk2_out</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.CLK.TX_MAC_ACLK.FREQ_HZ">125000000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.CLK.TX_MAC_ACLK.PHASE">0.000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.CLK.USERCLK2_OUT.ASSOCIATED_BUSIF"/>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.CLK.USERCLK2_OUT.ASSOCIATED_RESET"/>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.CLK.USERCLK2_OUT.CLK_DOMAIN">bd_5d9f_0_pcs_pma_0_userclk2_out</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.CLK.USERCLK2_OUT.FREQ_HZ">125000000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.CLK.USERCLK2_OUT.PHASE">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.CLK.USERCLK_OUT.ASSOCIATED_BUSIF"/>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.CLK.USERCLK_OUT.ASSOCIATED_RESET"/>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.CLK.USERCLK_OUT.CLK_DOMAIN">bd_5d9f_0_pcs_pma_0_userclk_out</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.CLK.USERCLK_OUT.FREQ_HZ">62500000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.CLK.USERCLK_OUT.PHASE">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.INTR.MAC_IRQ.PortWidth">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.INTR.MAC_IRQ.SENSITIVITY">EDGE_RISING</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.MDIO.BOARD.ASSOCIATED_PARAM">MDIO_BOARD_INTERFACE</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.MDIO.CAN_DEBUG">false</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.MGT_CLK.BOARD.ASSOCIATED_PARAM">DIFFCLK_BOARD_INTERFACE</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.MGT_CLK.CAN_DEBUG">false</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.MGT_CLK.FREQ_HZ">100000000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.MGT_CLK.TYPE">ETH_MGT_CLK</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.M_AXIS_RX.CLK_DOMAIN">bd_5d9f_0_pcs_pma_0_userclk2_out</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.M_AXIS_RX.FREQ_HZ">125000000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.M_AXIS_RX.HAS_TKEEP">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.M_AXIS_RX.HAS_TLAST">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.M_AXIS_RX.HAS_TREADY">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.M_AXIS_RX.HAS_TSTRB">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.M_AXIS_RX.LAYERED_METADATA">undef</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.M_AXIS_RX.PHASE">0.000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.M_AXIS_RX.TDATA_NUM_BYTES">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.M_AXIS_RX.TDEST_WIDTH">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.M_AXIS_RX.TID_WIDTH">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.M_AXIS_RX.TUSER_WIDTH">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.RST.GLBL_RST.POLARITY">ACTIVE_HIGH</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.RST.PHY_RST_N.BOARD.ASSOCIATED_PARAM">PHYRST_BOARD_INTERFACE</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.RST.PHY_RST_N.POLARITY">ACTIVE_LOW</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.RST.PMA_RESET_OUT.POLARITY">ACTIVE_HIGH</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.RST.RX_RESET.POLARITY">ACTIVE_HIGH</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.RST.S_AXI_LITE_RESETN.POLARITY">ACTIVE_LOW</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.RST.TX_RESET.POLARITY">ACTIVE_HIGH</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.SGMII.BOARD.ASSOCIATED_PARAM">ETHERNET_BOARD_INTERFACE</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXI.ADDR_WIDTH">12</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXI.ARUSER_WIDTH">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXI.AWUSER_WIDTH">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXI.BUSER_WIDTH">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXI.CLK_DOMAIN"/>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXI.DATA_WIDTH">32</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXI.FREQ_HZ">100000000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXI.HAS_BRESP">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXI.HAS_BURST">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXI.HAS_CACHE">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXI.HAS_LOCK">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXI.HAS_PROT">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXI.HAS_QOS">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXI.HAS_REGION">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXI.HAS_RRESP">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXI.HAS_WSTRB">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXI.ID_WIDTH">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXI.MAX_BURST_LENGTH">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXI.NUM_READ_OUTSTANDING">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXI.NUM_READ_THREADS">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXI.NUM_WRITE_OUTSTANDING">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXI.NUM_WRITE_THREADS">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXI.PHASE">0.000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXI.PROTOCOL">AXI4LITE</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXI.READ_WRITE_MODE">READ_WRITE</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXI.RUSER_BITS_PER_BYTE">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXI.RUSER_WIDTH">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXI.SUPPORTS_NARROW_BURST">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXI.WUSER_BITS_PER_BYTE">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXI.WUSER_WIDTH">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXIS_PAUSE.CLK_DOMAIN">bd_5d9f_0_pcs_pma_0_userclk2_out</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXIS_PAUSE.FREQ_HZ">125000000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXIS_PAUSE.HAS_TKEEP">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXIS_PAUSE.HAS_TLAST">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXIS_PAUSE.HAS_TREADY">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXIS_PAUSE.HAS_TSTRB">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXIS_PAUSE.LAYERED_METADATA">undef</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXIS_PAUSE.PHASE">0.000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXIS_PAUSE.TDATA_NUM_BYTES">2</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXIS_PAUSE.TDEST_WIDTH">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXIS_PAUSE.TID_WIDTH">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXIS_PAUSE.TUSER_WIDTH">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXIS_TX.CLK_DOMAIN">bd_5d9f_0_pcs_pma_0_userclk2_out</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXIS_TX.FREQ_HZ">125000000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXIS_TX.HAS_TKEEP">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXIS_TX.HAS_TLAST">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXIS_TX.HAS_TREADY">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXIS_TX.HAS_TSTRB">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXIS_TX.LAYERED_METADATA">undef</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXIS_TX.PHASE">0.000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXIS_TX.TDATA_NUM_BYTES">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXIS_TX.TDEST_WIDTH">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXIS_TX.TID_WIDTH">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="BUSIFPARAM_VALUE.S_AXIS_TX.TUSER_WIDTH">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.ClockSelection">Sync</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.Component_Name">axi_ethernet_0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.DIFFCLK_BOARD_INTERFACE">Custom</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.ENABLE_AVB">false</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.ENABLE_LVDS">false</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.ETHERNET_BOARD_INTERFACE">Custom</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.EnableAsyncSGMII">false</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.Enable_1588">false</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.Enable_1588_1step">false</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.Enable_Pfc">false</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.Frame_Filter">true</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.GTinEx">false</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.Include_IO">true</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.InstantiateBitslice0">false</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.MCAST_EXTEND">false</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.MDIO_BOARD_INTERFACE">Custom</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.Number_of_Table_Entries">4</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.PHYADDR">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.PHYRST_BOARD_INTERFACE">Custom</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.PHY_TYPE">SGMII</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.RXCSUM">None</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.RXMEM">4k</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.RXVLAN_STRP">false</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.RXVLAN_TAG">false</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.RXVLAN_TRAN">false</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.SIMULATION_MODE">false</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.Statistics_Counters">true</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.Statistics_Reset">false</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.Statistics_Width">64bit</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.SupportLevel">1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.TIMER_CLK_PERIOD">4000</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.TXCSUM">None</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.TXMEM">4k</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.TXVLAN_STRP">false</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.TXVLAN_TAG">false</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.TXVLAN_TRAN">false</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.Timer_Format">0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.TransceiverControl">false</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.USE_BOARD_FLOW">false</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.axiliteclkrate">100.0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.axisclkrate">100.0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.drpclkrate">50.0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.gt_type">GTH</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.gtlocation">X0Y0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.gtrefclkrate">125</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.gtrefclksrc">clk0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.lvdsclkrate">125</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.processor_mode">false</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.rxlane0_placement">DIFF_PAIR_0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.rxlane1_placement">DIFF_PAIR_1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.rxnibblebitslice0used">false</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.speed_1_2p5">1G</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.tx_in_upper_nibble">true</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.txlane0_placement">DIFF_PAIR_0</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PARAM_VALUE.txlane1_placement">DIFF_PAIR_1</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PROJECT_PARAM.ARCHITECTURE">zynquplus</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PROJECT_PARAM.BOARD">xilinx.com:zcu106:part0:2.2</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PROJECT_PARAM.DEVICE">xczu7ev</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PROJECT_PARAM.PACKAGE">ffvc1156</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PROJECT_PARAM.PREFHDL">VHDL</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PROJECT_PARAM.SILICON_REVISION"/>
<spirit:configurableElementValue spirit:referenceId="PROJECT_PARAM.SIMULATOR_LANGUAGE">MIXED</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PROJECT_PARAM.SPEEDGRADE">-2</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PROJECT_PARAM.TEMPERATURE_GRADE">E</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PROJECT_PARAM.USE_RDI_CUSTOMIZATION">TRUE</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="PROJECT_PARAM.USE_RDI_GENERATION">TRUE</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="RUNTIME_PARAM.IPCONTEXT">IP_Flow</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="RUNTIME_PARAM.IPREVISION">4</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="RUNTIME_PARAM.MANAGED">TRUE</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="RUNTIME_PARAM.OUTPUTDIR">.</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="RUNTIME_PARAM.SELECTEDSIMMODEL"/>
<spirit:configurableElementValue spirit:referenceId="RUNTIME_PARAM.SHAREDDIR">.</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="RUNTIME_PARAM.SWVERSION">2018.2</spirit:configurableElementValue>
<spirit:configurableElementValue spirit:referenceId="RUNTIME_PARAM.SYNTHESISFLOW">OOC_HIERARCHICAL</spirit:configurableElementValue>
</spirit:configurableElementValues>
<spirit:vendorExtensions>
<xilinx:componentInstanceExtensions>
<xilinx:configElementInfos>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.CLK.GTREF_CLK_OUT.CLK_DOMAIN" xilinx:valuePermission="bd"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.CLK.GTREF_CLK_OUT.FREQ_HZ" xilinx:valueSource="user" xilinx:valuePermission="bd_and_user"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.CLK.GTREF_CLK_OUT.PHASE" xilinx:valueSource="constant" xilinx:valuePermission="bd"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.CLK.RXUSERCLK2_OUT.CLK_DOMAIN" xilinx:valuePermission="bd"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.CLK.RXUSERCLK2_OUT.FREQ_HZ" xilinx:valueSource="user" xilinx:valuePermission="bd_and_user"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.CLK.RXUSERCLK2_OUT.PHASE" xilinx:valueSource="constant" xilinx:valuePermission="bd"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.CLK.RXUSERCLK_OUT.CLK_DOMAIN" xilinx:valuePermission="bd"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.CLK.RXUSERCLK_OUT.FREQ_HZ" xilinx:valueSource="user" xilinx:valuePermission="bd_and_user"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.CLK.RXUSERCLK_OUT.PHASE" xilinx:valueSource="constant" xilinx:valuePermission="bd"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.CLK.RX_MAC_ACLK.ASSOCIATED_BUSIF" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.CLK.RX_MAC_ACLK.ASSOCIATED_RESET" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.CLK.RX_MAC_ACLK.CLK_DOMAIN" xilinx:valueSource="propagated" xilinx:valuePermission="bd"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.CLK.RX_MAC_ACLK.FREQ_HZ" xilinx:valueSource="user" xilinx:valuePermission="bd_and_user"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.CLK.RX_MAC_ACLK.PHASE" xilinx:valuePermission="bd"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.CLK.S_AXI_LITE_CLK.ASSOCIATED_BUSIF" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.CLK.S_AXI_LITE_CLK.ASSOCIATED_CLKEN" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.CLK.S_AXI_LITE_CLK.ASSOCIATED_RESET" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.CLK.S_AXI_LITE_CLK.FREQ_HZ" xilinx:valueSource="default_prop"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.CLK.TX_MAC_ACLK.ASSOCIATED_BUSIF" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.CLK.TX_MAC_ACLK.ASSOCIATED_RESET" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.CLK.TX_MAC_ACLK.CLK_DOMAIN" xilinx:valueSource="propagated" xilinx:valuePermission="bd"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.CLK.TX_MAC_ACLK.FREQ_HZ" xilinx:valueSource="user" xilinx:valuePermission="bd_and_user"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.CLK.TX_MAC_ACLK.PHASE" xilinx:valuePermission="bd"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.CLK.USERCLK2_OUT.CLK_DOMAIN" xilinx:valuePermission="bd"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.CLK.USERCLK2_OUT.FREQ_HZ" xilinx:valueSource="user" xilinx:valuePermission="bd_and_user"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.CLK.USERCLK2_OUT.PHASE" xilinx:valueSource="constant" xilinx:valuePermission="bd"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.CLK.USERCLK_OUT.CLK_DOMAIN" xilinx:valuePermission="bd"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.CLK.USERCLK_OUT.FREQ_HZ" xilinx:valueSource="user" xilinx:valuePermission="bd_and_user"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.CLK.USERCLK_OUT.PHASE" xilinx:valueSource="constant" xilinx:valuePermission="bd"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.INTR.MAC_IRQ.SENSITIVITY" xilinx:valueSource="user" xilinx:valuePermission="bd"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.MDIO.BOARD.ASSOCIATED_PARAM" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.MGT_CLK.BOARD.ASSOCIATED_PARAM" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.MGT_CLK.FREQ_HZ" xilinx:valuePermission="bd_and_user"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.MGT_CLK.TYPE" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.M_AXIS_RX.CLK_DOMAIN" xilinx:valueSource="propagated" xilinx:valuePermission="bd"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.M_AXIS_RX.FREQ_HZ" xilinx:valueSource="user" xilinx:valuePermission="bd"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.M_AXIS_RX.HAS_TKEEP" xilinx:valueSource="constant" xilinx:valuePermission="bd"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.M_AXIS_RX.HAS_TLAST" xilinx:valueSource="constant" xilinx:valuePermission="bd"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.M_AXIS_RX.HAS_TREADY" xilinx:valueSource="constant" xilinx:valuePermission="bd"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.M_AXIS_RX.HAS_TSTRB" xilinx:valueSource="constant" xilinx:valuePermission="bd"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.M_AXIS_RX.LAYERED_METADATA" xilinx:valuePermission="bd"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.M_AXIS_RX.PHASE" xilinx:valuePermission="bd"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.M_AXIS_RX.TDATA_NUM_BYTES" xilinx:valueSource="constant" xilinx:valuePermission="bd"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.M_AXIS_RX.TDEST_WIDTH" xilinx:valueSource="constant" xilinx:valuePermission="bd"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.M_AXIS_RX.TID_WIDTH" xilinx:valueSource="constant" xilinx:valuePermission="bd"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.M_AXIS_RX.TUSER_WIDTH" xilinx:valueSource="constant" xilinx:valuePermission="bd"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.RST.GLBL_RST.POLARITY" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.RST.PHY_RST_N.BOARD.ASSOCIATED_PARAM" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.RST.PHY_RST_N.POLARITY" xilinx:valueSource="user" xilinx:valuePermission="bd"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.RST.PMA_RESET_OUT.POLARITY" xilinx:valueSource="user" xilinx:valuePermission="bd"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.RST.RX_RESET.POLARITY" xilinx:valueSource="constant" xilinx:valuePermission="bd"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.RST.S_AXI_LITE_RESETN.POLARITY" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.RST.TX_RESET.POLARITY" xilinx:valueSource="constant" xilinx:valuePermission="bd"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.SGMII.BOARD.ASSOCIATED_PARAM" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_AXI.ADDR_WIDTH" xilinx:valueSource="user_prop"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_AXI.ARUSER_WIDTH" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_AXI.AWUSER_WIDTH" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_AXI.BUSER_WIDTH" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_AXI.CLK_DOMAIN" xilinx:valuePermission="bd"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_AXI.DATA_WIDTH" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_AXI.FREQ_HZ" xilinx:valuePermission="bd"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_AXI.HAS_BURST" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_AXI.HAS_CACHE" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_AXI.HAS_LOCK" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_AXI.HAS_PROT" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_AXI.HAS_QOS" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_AXI.HAS_REGION" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_AXI.HAS_WSTRB" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_AXI.ID_WIDTH" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_AXI.PHASE" xilinx:valuePermission="bd"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_AXI.PROTOCOL" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_AXI.RUSER_WIDTH" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_AXI.WUSER_WIDTH" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_AXIS_PAUSE.CLK_DOMAIN" xilinx:valueSource="propagated" xilinx:valuePermission="bd"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_AXIS_PAUSE.FREQ_HZ" xilinx:valueSource="user" xilinx:valuePermission="bd"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_AXIS_PAUSE.HAS_TKEEP" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_AXIS_PAUSE.HAS_TLAST" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_AXIS_PAUSE.HAS_TREADY" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_AXIS_PAUSE.HAS_TSTRB" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_AXIS_PAUSE.PHASE" xilinx:valuePermission="bd"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_AXIS_PAUSE.TDATA_NUM_BYTES" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_AXIS_PAUSE.TDEST_WIDTH" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_AXIS_PAUSE.TID_WIDTH" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_AXIS_PAUSE.TUSER_WIDTH" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_AXIS_TX.CLK_DOMAIN" xilinx:valueSource="propagated" xilinx:valuePermission="bd"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_AXIS_TX.FREQ_HZ" xilinx:valueSource="user" xilinx:valuePermission="bd"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_AXIS_TX.HAS_TKEEP" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_AXIS_TX.HAS_TLAST" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_AXIS_TX.HAS_TREADY" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_AXIS_TX.HAS_TSTRB" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_AXIS_TX.PHASE" xilinx:valuePermission="bd"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_AXIS_TX.TDATA_NUM_BYTES" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_AXIS_TX.TDEST_WIDTH" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_AXIS_TX.TID_WIDTH" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="BUSIFPARAM_VALUE.S_AXIS_TX.TUSER_WIDTH" xilinx:valueSource="constant"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.PHY_TYPE" xilinx:valueSource="user"/>
<xilinx:configElementInfo xilinx:referenceId="PARAM_VALUE.processor_mode" xilinx:valueSource="user"/>
</xilinx:configElementInfos>
</xilinx:componentInstanceExtensions>
</spirit:vendorExtensions>
</spirit:componentInstance>
</spirit:componentInstances>
</spirit:design>
nanz
Hi @tchin123 ,
Can you not even zip it up and share?
You should not have problems to share XCI. It's very hard to work with the plain text file here.
tchin123
You're right, here is the zip
nanz
Hi @tchin123 ,
I checked the XCI file and mac_irq is there.
