PL ETHERNET TEST ON ZCU102
Hello all,
I Have downloaded design file from xapp1306 link. In that , for PL 1G ETHERNET, I generated the bitstream--> export to hardware--> Launch SDK . After this in SDK i got hardware file. After that in SDK i imported LWiP (from Template). Then i run the application.
Basically i want to test pinging.  But i am not able to ping after running the LWiP application.
My Host setting is 192.168.1.12.
Please tell me where i am wrong.
Did you try running ready to test images?
@shabbirk
Ready to test i tried. That is working fine. I want to generate my own images.
please help
hi @vikaskanha ,
Did you getr any error in application while running it on hardware? Please try to chagne the phy speed from auto negotiation to 100Mbps in bsp settings and test it once.
Best Regards,
Srikanth
