Observer pmm
Packetize Data Stream To Send Over Ethernet
Hi everyone,
So, I have a data stream that I want to packetize/encapsulate and sent over 10G Ethernet.
I've been searching for a while but haven't found any IP core that could help me with this.
Do I have to implement it myself ? Is there any IP core that I am missing ? Does the "10G Ethernet Subsystem" already deal with it ?
I'm relatively new to the "FPGA world" so forgive me any mistakes or basic questions.
Pedro Marques.
Re: Packetize Data Stream To Send Over Ethernet
You can generate HW evaluation license from the evaluate option from below link which will generate time limited bit file to use for Evaluation testing.
https://www.xilinx.com/products/intellectual-property/do-di-10gemac.htm.html#overview
The core comes with an example design(refer PG157 for more details) which has simple frame generator, monitor and FIFO logic for sending and receiving frames through the core and you can use it as starting point.
Satish
Scholar hbucher
@pmm Pedro
You would typically feed the 10G subsystem with a DMA engine
https://www.xilinx.com/support/documentation/ip_documentation/axi_dma/v7_1/pg021_axi_dma.pdf
But if you are new to the FPGA world this is not a trivial task.
For once, I believe the 10G core requires a special license (the one in Vivado wont allow you to synthesize  generate a bitfile).
Can you provide more details on what card/software you are using?
Satish
Observer pmm
Thanks @hbucher and @yenigal for the replies,
Okay, maybe I'm new but not that much new :)
I already have two Kintex-7 KC705 communicating with each other through 10Gbps Ethernet over an optical link (SFP+). I'm using the 10G Ethernet Subsystem example design with the pattern generator/checker active in both boards to test the link.
Now I want to move on the the next step, feeding one board with a data stream, encapsulate/packetize that data over Ethernet and send it to the other board were I want to do the reverse.
What is the source of the data stream and what is your application.
Does it have upper layers of protocol stack or just sending Ethernet frames.
You can directly drive the axi stream using the fifo's if it is Ethernet frames.
Satish
