Problem with Lwip udp send and receive packets using Microblaze
I am trying to implement LWIP UDP design using Microblaze on Artix-7 evaluation board. I am presently using Vivado 2018.2 ver. I have generated application project for both udp_perf_server and udp_perf_client.Both are separately working. Problem is how to add both send and receive sections in the same main.c file and how to make sending and receiving parallel and independent in the SDK section??
Thank you
Re: Problem with Lwip udp send and receive packets using Microblaze
Hi manasam@bel.co.in ,
The LWIP example designs are specifically made for client/server purpose to achieve the max performance with customers' tune the parameters per thier system. You can create your own applications which may combine the two and with a switch on/off in between.
"Don't forget to reply, kudo and accept as solution."
