RXAUI 8b/10b coding before interleave or interleave before coding
Hi everyone
Now I am debugging the connection between the phy IC and the rxaui PCS/PMA.
the phy IC  apply 8/10 encoding first and then interleave at the 10bit level as default , but the pg083 just  descriped as follow " the data on each lane is 8B/10B encoded before transmission " Does it mean that the coding before interleave ?
after I changed the setting to " interleave two 8bit stream first and then apply 8/10 encoding',the connection between phy IC and  rxaui PCS/PMA success.
So my question is that whether the rxaui uses coding before interleave  or not!
Re: RXAUI 8b/10b coding before interleave or interleave before coding
The core interleaves the two channels and then 8b10b encoding is done in the transceivers
Satish
Satish
I believe the interleaving is meant to happen at the 10B level.
I would refer you to the specification, but I can't find an online link on Marvell's website right now.  There seems to be a copy cached at Opencores though.
Allan
@yenigal wrote:
I'm curious - when the Xilinx core was tested, what was it tested against?
Thanks a lot!
could you tell me which document describe the details?
