as_so
RoE on Zcu102 board
Hello everyone,
I have a problem with the example design of the RoE (pg312), I cannot ping from the zcu102 board to a PC or vice versa.
I have generated the design with Vivado 2020.1, I have downloaded the soft of the framer from the github wireless-apps and the ethernet (pg210) driver from Linux Axi Ethernet Driver. I have built  the system with Petalinux 2019.2.
I can see ethernet packets transmitted by the framer. But I don’t know why I can’t ping !!
Is it a problem of versions compatibility between Vivado / Petalinux?
Is it a problem with the ethernet driver?
Or what problem could there be ?
Any help is appreciated.
thank you
guozhenp
So do you have the 10G/25G network card in your pc and have installed network adapter driver using Device Manager?
Does 10G/25G IP in RoE have got block_lock?
as_so
Yes, the 10G driver seems to be working fine. The Pc has received 5Gbps of Ethernet frames from the RoE framer.
The zcu102 LED0 is flashing which means that the block lock is ok.
But there is an error message when booting:
xilinx_axienet a0020000.ethernet eth0: XXV MAC block lock not complete! Cross-check the MAC ref clock configuration
