Run-time selectable baud rate for Aurora 8b10b?
I'm afraid not, just asking, is it possible to use Aurora with a selectable frequency?
回复: Run-time selectable baud rate for Aurora 8b10b?
Do you mean you want to change the line rate on the fly?
I don't think Aurora has the option.
Re: Run-time selectable baud rate for Aurora 8b10b?
hi @archangel-lightworks ,
i believe you can use DRP , The dynamic reconfiguration port (DRP) is an integral part of CMTs, clock management, XADC, serial transceivers, and the PCIe block.
through the DRP you can the change the line rate .
Chandra sekhar
Kindly note- Please mark the Answer as "Accept as solution" if solution provided is helpful.
