mengmcxl
SGMII core configuration without MDIO
To config a SGMII core running 100mbps, can I just use an_adv_config_vector[]15:0] to config that speed, without use the MDIO port as the attached ?
nmoeller
Hey @mengmcxl,
Yes, the MDIO Management Interface is optional. You can actually remove it by re-customizing the IP, then go the "Core Functionality" tab and uncheck "MDIO Management Interface".
Table 2-9 in PG047 shows how most of the registers can be written without MDIO, but it looks like you've already taken care of that.
Nicholas Moellers
Xilinx Worldwide Technical Support
nmoeller
Hey @mengmcxl,
Nicholas Moellers
mengmcxl
Great, Thanks
nanz
Hi @mengmcxl ,
If your question has been answered, would you please mark this forum post as "accepted solution"?
So other users can benifit from it.
Thank you!
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs and our Versal Ethernet Sticky Note.
