agordon
Send data file from PC to Zynq - Ethernet
Hi all,
Wondering if there might be any examples out there involving transmission of a simple txt file from PC to FPGA via Ethernet. I have searched the forums here along with other online sources, but have not found anything concrete yet. Any suggestions or directional pointers would be appreciated!
Thank you!
Tags (3)
nanz
Hi @agordon ,
We do not have the exact example you are requesting, but you can check XAPP1026 as a starting point:
https://www.xilinx.com/support/documentation/application_notes/xapp1026.pdf
If starting with Versal take a look at our Versal Design Process Hub and our Versal Blogs and our Versal Ethernet Sticky Note.
