Timestamping Ethernet on Artix-based EMAC
is there some workaround for timestamping Eth traffic on Artix-based system? My current implementation targets Artix with RGMII interface to external PHY, which I notice is a double problem - Timestamping is enabled only for 7series GTH and GTX, in SGMII/1000BASEX mode. is this the only combination that works, or is it possible to use Kintex with RGMII, or Artix with GTPs?
Srdjan
Re: Timestamping Ethernet on Artix-based EMAC
Hi @srdjan.opacic,
Yes, unfortunately that is what we only support.
"Don't forget to reply, kudo and accept as solution."
Hi @nanz,
Thanks for the reply, that is unfortunate. Do you know are there plans to develop this in the near future? Can you tell me if there is a workaround for this situation (I assume someone already wanted to timestamp Ethernet without SGMII, so they had the same problem)? Any help would be appreciated.
Best regards
Srdjan
