Tri-mode Ethernet MAC example on ml506 not work.
hi , i learning to use Temac provide by xilinx. there is a tutorial at here,http://www.fpgadeveloper.com/2008/10/tri-mode-ethernet-mac.html . i downloaded project example  but it not work on my ml506 board, tx led is not blink. i use edk 10.1.3, Anybody tested this project on ml506?  thanks.
Anonymous
Not applicable
hi
why dont you use coregen to generate temac? I think it is a easier way. you can use example design which coregen generates! try it!
help me, please!
Anonymous
Not applicable
I think this is a question that would be better answered on a different forum section.  Since you are having an issue getting the tri-mode emac working, it would be better to have this answered in that forum.  I'll move this over for you and you will more likely get an answer there.
Anonymous
Not applicable
hi
 this tutorial use coregen too. if design without this tut, I don't know how to modify UCF file and top modul file, i tried to do it but project still not work . can you guide modify them for my board, step by step? thanks.
Anonymous
Not applicable
I have'nt do this for ml506, i generate temac for spartan3e board and I dont know exactly the diffrences but here i mention some important points : (I think there are some other similar posts which can help you, do some google)
- after generating temac core, coregen generates example_design.vhd. use it as a component in your top module. in entity declaration part add a port for reseting the phy (the reset of my PHY is active low) :
entity faeze_temac is
    port(
      -- asynchronous reset
      reset_phy            : inout std_logic:='0';
      -- Client Receiver Statistics Interface
      rx_statistics_vector : out std_logic;
      rx_statistics_valid  : out std_logic;
- then set the reset in your code (something like this )
 process (clk_in) begin
    cnt <= cnt + 1;
    if cnt > 50 then
         reset_phy       <= '1';
         reset               <= '0';   --temac reset
    end if;
 end process;
- in your ucf file just mention your pin assignment, like this :
NET      "clk_in"       LOC=F11;
NET      "reset_phy"    LOC=R13;
NET      "mii_txd[0]"   LOC=P8;
NET      "mii_txd[1]"   LOC=Y7;
NET      "mii_txd[2]"   LOC=Y5;
NET      "mii_txd[3]"   LOC=U4;
NET      "mii_tx_en"    LOC=R9;
NET      "mii_tx_er"    LOC=Y13;
- now you can send some packets from the pc to the board, it will return it to your pc and you can capture them. for sending packets i use my own raw socket code which sends packets to the board(with specific MAC address) but the other said me I can just send packets by pinging( i dont test it) i think in this case you should disable address filter (i am not sure)
good luck
Anonymous
Not applicable
and I use configuration vector to confgiure the temac core, and dont forget to set proper configurations.
thank you verymuch for your answer. however, your temac is soft core, and my temac on virtex5 is hardcore. i will try it. anybody tested on ml506 board still help me for more detail on my board. thanks again fk
Hi @ashimo
I have just tested on ML509, it is OK
Tuan_Gcs
